Introducción
This replacement guide will help you get through all of the top pieces such as the filter element to get to the drip spring. It is possible for this spring to break causing issues with the drip function or rust possibly causing a strange taste.
8 personas más completaron esta guía.
4 comentarios
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
