Saltar al contenido principal
Cuisinart CPB-380 Power Cord Replacement
Qué necesitas
  1. Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: paso 1, imagen 1 de 3 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: paso 1, imagen 2 de 3 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: paso 1, imagen 3 de 3
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Power Cord Replacement: paso 2, imagen 1 de 2 Cuisinart CPB-380 Power Cord Replacement: paso 2, imagen 2 de 2
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Power Cord Replacement: paso 3, imagen 1 de 3 Cuisinart CPB-380 Power Cord Replacement: paso 3, imagen 2 de 3 Cuisinart CPB-380 Power Cord Replacement: paso 3, imagen 3 de 3
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Power Cord Replacement: paso 4, imagen 1 de 3 Cuisinart CPB-380 Power Cord Replacement: paso 4, imagen 2 de 3 Cuisinart CPB-380 Power Cord Replacement: paso 4, imagen 3 de 3
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Power Cord Replacement: paso 5, imagen 1 de 2 Cuisinart CPB-380 Power Cord Replacement: paso 5, imagen 2 de 2
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Power Cord Replacement, Power Cord: paso 6, imagen 1 de 2 Cuisinart CPB-380 Power Cord Replacement, Power Cord: paso 6, imagen 2 de 2
    • Remove the 2 black, yellow, and red wires from circuit board by push down on the tab to release and then pull up.
  7. Cuisinart CPB-380 Power Cord Replacement: paso 7, imagen 1 de 1
    • Pinch perpendicular to the flat surface and pull out the black wire.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 130
