Saltar al contenido principal
Cuisinart CHW-12 Power Cord Replacement
Qué necesitas
  1. Cuisinart CHW-12 Power Cord Replacement, Power Cord: paso 1, imagen 1 de 2 Cuisinart CHW-12 Power Cord Replacement, Power Cord: paso 1, imagen 2 de 2
    • Unplug the coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Cuisinart CHW-12 Power Cord Replacement: paso 2, imagen 1 de 2 Cuisinart CHW-12 Power Cord Replacement: paso 2, imagen 2 de 2
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Cuisinart CHW-12 Power Cord Replacement: paso 3, imagen 1 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 3, imagen 2 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 3, imagen 3 de 3
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Pull the gray ribbon cable strait out of the black containment box.
  4. Cuisinart CHW-12 Power Cord Replacement: paso 4, imagen 1 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 4, imagen 2 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 4, imagen 3 de 3
    • Locate the Phillips head screws holding the highlighted plastic shield in place.
    • Remove the two 14mm screws with a Phillips head screwdriver.
    • Carefully slide the shield out of place along the power cord and set it aside.
  5. Cuisinart CHW-12 Power Cord Replacement: paso 5, imagen 1 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 5, imagen 2 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 5, imagen 3 de 3
    • Remove the two 14mm Phillips head screws securing the plastic containment box.
    • Pull the plastic containment box straight out of the coffee maker.
  6. Cuisinart CHW-12 Power Cord Replacement: paso 6, imagen 1 de 2 Cuisinart CHW-12 Power Cord Replacement: paso 6, imagen 2 de 2
    • Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
    • Pull the top from the plastic housing.
  7. Cuisinart CHW-12 Power Cord Replacement: paso 7, imagen 1 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 7, imagen 2 de 3 Cuisinart CHW-12 Power Cord Replacement: paso 7, imagen 3 de 3
    • Pull the circuit board out of the containment box.
    • Locate the power cable connection point on the circuit board.
    • Desolder the power cable wires connected to the board.
    • Solder iron can cause burns if used improperly.
    • Replace the power cable with the corresponding wires of the new power cable.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 11
Ultimos 30 días: 33
Todo El Tiempo: 1,759
