Saltar al contenido principal
Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement
Qué necesitas
  1. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement, Recoil Starter: paso 1, imagen 1 de 1
    • Remove the four screws from the hood of the lawnmower using a Phillips #0 screwdriver.
  2. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 2, imagen 1 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 2, imagen 2 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 2, imagen 3 de 3
    • Remove the hood of the lawnmower by pulling up.
  3. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 3, imagen 1 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 3, imagen 2 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 3, imagen 3 de 3
    • Using a wrench, remove the three nuts from the lawnmower’s defective recoil starter.
  4. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 4, imagen 1 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 4, imagen 2 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 4, imagen 3 de 3
    • Remove the defective recoil starter by pulling up.
  5. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 5, imagen 1 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 5, imagen 2 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 5, imagen 3 de 3
    • Place the new recoil starter in the lawnmower where the defective one was prior.
  6. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 6, imagen 1 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 6, imagen 2 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 6, imagen 3 de 3
    • Tighten the new recoil starter onto the lawnmower with a wrench and the nuts you had removed earlier.
  7. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 7, imagen 1 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 7, imagen 2 de 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: paso 7, imagen 3 de 3
    • Tighten the hood back onto the lawnmower with a Phillips #0 screwdriver and the four screws you had removed previously.
    • Make sure not to screw the hood on too tightly.
Linea de Meta
Andres Dominguez
Miembro Desde 01/26/22
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 23
Ultimos 30 días: 128
Todo El Tiempo: 1,808
