1. Flip your bike so the seat and handlebars are on the ground.
    • Flip your bike so the seat and handlebars are on the ground.
  2. Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
  5. Center the wheel and pull back to tighten the chain
    • Center the wheel and pull back to tighten the chain
  6. With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • Wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
Conclusión
Una persona más ha completado esta guía.
Erin Heimburge
Miembro Desde 11/07/13
27 Reputación
1 Guía escrita
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 58
Todo El Tiempo: 5,610
