Introducción
If your record is spinning at a varying speed or not at all, used this guide to replace the belt. Belts can wear out with age or due to temperature variation. Nimble fingers will help with the most difficult step, not overstretching the new belt. Before beginning, be sure to disconnect the device from any external power source.
Qué necesitas
Remove the slipmat and locate the small, round clip which holds the turntable platter to the turntable.
Insert the iFixit opening tool between the spindle and the clip and pry off the clip.
Turn the platter back over and place it on the spindle.
Spin the platter 2 times clockwise to unloop the band from the raised prong on the platter and to loop it around the raised prong on the turntable base. This allows the circular motion of the motor to spin the band and the turntable platter.
You may replace the round clip at this point though it is not important to the sound quality of the turntable.
Now, spin some tunes and enjoy your improved sound!
4 personas más completaron esta guía.
