Saltar al contenido principal
Crosley CR704 Speaker Replacement
Qué necesitas
  1. Crosley CR704 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Crosley CR704 Speaker Replacement: paso 2, imagen 1 de 1
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Crosley CR704 Speaker Replacement: paso 3, imagen 1 de 1
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Crosley CR704 Speaker Replacement: paso 4, imagen 1 de 1
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
Conclusión
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
Una persona más ha completado esta guía.
MarkAnthony
Miembro Desde 09/22/13
772 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Miembros
5 Guías creadas
Un comentario
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 25
Todo El Tiempo: 2,854
