Saltar al contenido principal
Crosley CR704 Control Knobs Replacement
Qué necesitas
  1. Crosley CR704 Control Knobs Replacement, Safety: paso 1, imagen 1 de 1
    • Unplug the power cable if it is plugged in so that you don't electrocute yourself or loved ones.
    • Make sure the turntable cover is closed so that nothing jostles out of place.
  2. Crosley CR704 Control Knobs Replacement: paso 2, imagen 1 de 1
    • Using a spudger, gain a position of leverage and insert the end of the spudger into the gap between the radio knob and the device.
    • With some force, pry the knob off of its peg.
    • The knob should slide off smoothly, but beware of flying knobs!
  3. Crosley CR704 Control Knobs Replacement: paso 3, imagen 1 de 1
    • Applying some force, insert the replacement knob onto the peg.
Conclusión
Test by turning on your radio and playing a tune. We suggest "Last Dance" by Dona Summer.
MarkAnthony
Miembro Desde 09/22/13
772 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 1,818
