Saltar al contenido principal
Crosley CR42 Power Cable Replacement
Qué necesitas
  1. Crosley CR42 Power Cable Replacement, Power Cable: paso 1, imagen 1 de 2 Crosley CR42 Power Cable Replacement, Power Cable: paso 1, imagen 2 de 2
    • Turn the device around until you are looking at the line-out port.
    • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  2. Crosley CR42 Power Cable Replacement: paso 2, imagen 1 de 3 Crosley CR42 Power Cable Replacement: paso 2, imagen 2 de 3 Crosley CR42 Power Cable Replacement: paso 2, imagen 3 de 3
    • Gently remove the back of the device. It should be connected by two wires.
  3. Crosley CR42 Power Cable Replacement: paso 3, imagen 1 de 3 Crosley CR42 Power Cable Replacement: paso 3, imagen 2 de 3 Crosley CR42 Power Cable Replacement: paso 3, imagen 3 de 3
    • Gently remove both wires.
    • After de-threading the antenna wire, remove the back of the device and set it aside.
  4. Crosley CR42 Power Cable Replacement: paso 4, imagen 1 de 3 Crosley CR42 Power Cable Replacement: paso 4, imagen 2 de 3 Crosley CR42 Power Cable Replacement: paso 4, imagen 3 de 3
    • Locate where the power cable connects to the device.
    • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  5. Crosley CR42 Power Cable Replacement: paso 5, imagen 1 de 3 Crosley CR42 Power Cable Replacement: paso 5, imagen 2 de 3 Crosley CR42 Power Cable Replacement: paso 5, imagen 3 de 3
    • With the pliers, remove the wire connectors. You may need to be forceful
    • It is wise to attach a marking in order to recognize how the wires should be reattached.
  6. Crosley CR42 Power Cable Replacement: paso 6, imagen 1 de 3 Crosley CR42 Power Cable Replacement: paso 6, imagen 2 de 3 Crosley CR42 Power Cable Replacement: paso 6, imagen 3 de 3
    • Pull apart both groups of wires.
    • After getting your replacement power cord, make sure you recognize how the wires should reattach.
  7. Crosley CR42 Power Cable Replacement: paso 7, imagen 1 de 3 Crosley CR42 Power Cable Replacement: paso 7, imagen 2 de 3 Crosley CR42 Power Cable Replacement: paso 7, imagen 3 de 3
    • Twist the connecting wires together.
    • Attach the twist-on wire connectors to the exposed wires.
Conclusión
Una persona más ha completado esta guía.
Eric Dybsetter
Miembro Desde 01/26/14
175 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 1-38, Maness Winter 2014 Miembro de Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 38
Todo El Tiempo: 6,329
