Saltar al contenido principal
Crosley CR42 Bushings Replacement
Qué necesitas
  1. Crosley CR42 Bushings Replacement, Bushings: paso 1, imagen 1 de 2 Crosley CR42 Bushings Replacement, Bushings: paso 1, imagen 2 de 2
    • Turn the device around so the line out port faces you.
    • Remove the ten 12 mm screws with the Phillips screwdriver.
  2. Crosley CR42 Bushings Replacement: paso 2, imagen 1 de 3 Crosley CR42 Bushings Replacement: paso 2, imagen 2 de 3 Crosley CR42 Bushings Replacement: paso 2, imagen 3 de 3
    • Pull the line out port toward you so you can view the inside of the Crosley.
    • Locate the wires that connect the line out port to the inside of the device.
  3. Crosley CR42 Bushings Replacement: paso 3, imagen 1 de 3 Crosley CR42 Bushings Replacement: paso 3, imagen 2 de 3 Crosley CR42 Bushings Replacement: paso 3, imagen 3 de 3
    • Pull on the two connections to remove them from the back of the line out port.
    • Remove the antenna wire from the line out port, then remove the line out port and set it aside.
  4. Crosley CR42 Bushings Replacement: paso 4, imagen 1 de 2 Crosley CR42 Bushings Replacement: paso 4, imagen 2 de 2
    • Remove the red and black connection underneath the turntable.
  5. Crosley CR42 Bushings Replacement: paso 5, imagen 1 de 1
    • Position yourself in front of the turntable to unscrew the three bushing bolts.
  6. Crosley CR42 Bushings Replacement: paso 6, imagen 1 de 3 Crosley CR42 Bushings Replacement: paso 6, imagen 2 de 3 Crosley CR42 Bushings Replacement: paso 6, imagen 3 de 3
    • Unscrew the three bushing bolts with the Phillips screw driver.
  7. Crosley CR42 Bushings Replacement: paso 7, imagen 1 de 2 Crosley CR42 Bushings Replacement: paso 7, imagen 2 de 2
    • Pull the turntable out from the casing.
    • Remove the three bushing bolts.
  8. Crosley CR42 Bushings Replacement: paso 8, imagen 1 de 3 Crosley CR42 Bushings Replacement: paso 8, imagen 2 de 3 Crosley CR42 Bushings Replacement: paso 8, imagen 3 de 3
    • Pinch the rubber bushing at the bottom, then pull downwards to remove it.
    • Repeat the previous step for the other two bushings.
Conclusión
Una persona más ha completado esta guía.
Roberto Rosila
Miembro Desde 01/26/14
319 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-38, Maness Winter 2014 Miembro de Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 3,064
