Saltar al contenido principal
Introducción
The sealing ring allows the pot to pressurize and seal properly. A missing or damaged sealing ring can lead to device failure. Use this quick and easy replacement guide to fix any problems pertaining to the sealing ring in your Crock-Pot Express Crock Multi-Cooker.
  1. Remove the power cord from  the wall outlet first, disconnecting power from the device.
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Grasp the power cord input connector firmly with forefinger and thumb. Without tugging, apply pulling force until the connector is free from device
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
  4. Orient the crock pot where the lid locked and unlocked icons are visible. Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other. Remove the lid.
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  5. Flip the lid over, exposing the underside and sealing ring.
    • Flip the lid over, exposing the underside and sealing ring.
  6. Using a plastic opening tool, work your way in between the metal and sealing ring. Continue to rotate and pry with the plastic opening tool until the sealing ring separates from the top.
    • Using a plastic opening tool, work your way in between the metal and sealing ring.
    • Continue to rotate and pry with the plastic opening tool until the sealing ring separates from the top.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 11
Últimos 30 Días: 52
Todo El Tiempo: 668
