Introducción
The sealing ring allows the pot to pressurize and seal properly. A missing or damaged sealing ring can lead to device failure. Use this quick and easy replacement guide to fix any problems pertaining to the sealing ring in your Crock-Pot Express Crock Multi-Cooker.
Qué necesitas
Remove the power cord from the wall outlet first, disconnecting power from the device.
Orient the crock pot where the lid locked and unlocked icons are visible.
Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
Remove the lid.
2 personas más completaron esta guía.
8Guía Comentarios
Thank you for giving me the answer to how to be sure I assemble the seal correctly in the Crock Pot Express after we clean the cooker after I unboxed it. A video should be included with the Crock pot Express , it wwould help a lot. There were no pictures of the underside of the lid. The placement of gasket is very crucial to safety. I used a pressure scanner years ago. Iam impressed with the E6 flashing on the control panel. I do like the cooker overall!
Thank you very much for the advice. Now I can make sure I am placing the gasket in the cooker correctly. I used a pressure scanner/ cooker 30years ago! I like the e6 warning which was on the control panel to let me know that the pressure was not building up. I was able to let the steam off.
This gasket / seal seems very loose and ill fitting. Is this normal?
Where do I find the question & response to gnag321 ?
I have same question as mark.e.betty. I seem to have the seal in in the only way it will fit. Please advise as I love this machine & want to a lot more cooking. Tks
