Introducción
If you need to replace the roller bar, use this guide to access and remove it. If the roller bar becomes excessively scratched or damaged, consistently gets stuck, or does not roll properly, it may need to be replaced.
Use the Front Door Replacement Guide as a prerequisite to access the interior parts of the Cricut. None of these steps are extremely difficult, but the maneuvering of the Cricut shell to access the roller bar requires careful attention, as it would be easy to break something.
Qué necesitas
On both the left and right sides of the Cricut, locate the two internal screws.
Use a Phillips #1 screwdriver bit to unscrew the top 10.8 mm screw and the lower 9.1 mm screw on each side, four screws in total.
Locate the spring on the left side of the Cricut's metal interior frame.
Gently remove the spring by disconnecting the hooks on either side.
Repeat on the right side.
Una persona más ha completado esta guía.
