Saltar al contenido principal
Cricut Explore Air 2 Roller Bar Motor Replacement
Qué necesitas
  1. Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: paso 1, imagen 1 de 2 Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: paso 1, imagen 2 de 2
    • With the Cricut open, access the two internal screws on the front left side.
    • Use the Phillips #1 screwdriver to remove the top 10.82 mm screw and the bottom 9.1 mm screw.
  2. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 2, imagen 1 de 2 Cricut Explore Air 2 Roller Bar Motor Replacement: paso 2, imagen 2 de 2
    • Rotate the Cricut so the bottom is facing upwards.
    • Identify the two screws with pads.
    • Using the Phillips #2 screwdriver, remove both 42.77 mm screws.
  3. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 3, imagen 1 de 1
    • Rotate the Cricut back to its upright position.
    • Gently lift the cover on the left side of the machine to reveal the parts underneath.
  4. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 4, imagen 1 de 2 Cricut Explore Air 2 Roller Bar Motor Replacement: paso 4, imagen 2 de 2
    • Locate the circuit board on the cover just removed.
    • Use the Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  5. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 5, imagen 1 de 1
    • Gently unplug the connector, removing the circuit board.
  6. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 6, imagen 1 de 1
    • Gently unplug the connector located on the roller bar motor.
  7. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 7, imagen 1 de 1
    • Locate the three screws securing the plate holding the roller bar motor to the Cricut.
    • Use the Phillips #1 screwdriver to remove each of the three 5 mm screws.
  8. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 8, imagen 1 de 1
    • Remove the motor from the interior of the Cricut.
  9. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 9, imagen 1 de 1
    • Gently remove the white gear from the roller bar motor.
  10. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 10, imagen 1 de 1
    • Locate the two screws holding the roller bar motor to the mounting plate.
    • Use the Phillips #1 screwdriver to remove the two 2 mm screws.
  11. Cricut Explore Air 2 Roller Bar Motor Replacement: paso 11, imagen 1 de 1
    • Remove the motor from the plate.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 44
Todo El Tiempo: 339
