Saltar al contenido principal
Creative Ziio 7" LCD Screen Replacement
Qué necesitas
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: paso 1, imagen 1 de 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: paso 1, imagen 2 de 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: paso 1, imagen 3 de 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: paso 2, imagen 1 de 1
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: paso 4, imagen 1 de 3 Creative Ziio 7" LCD Screen Replacement: paso 4, imagen 2 de 3 Creative Ziio 7" LCD Screen Replacement: paso 4, imagen 3 de 3
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: paso 5, imagen 1 de 1
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: paso 6, imagen 1 de 1
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: paso 7, imagen 1 de 2 Creative Ziio 7" LCD Screen Replacement: paso 7, imagen 2 de 2
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: paso 8, imagen 1 de 1
    • Carefully remove the black LCD screen.
Conclusión
2 personas más completaron esta guía.
Kyle
Miembro Desde 04/16/13
111 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-10, Maness Spring 2013 Miembro de Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Miembros
13 Guías creadas
2 comentarios
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - Contestar
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,352
