Saltar al contenido principal
Creative Zen X-Fi LCD Screen Replacement
Qué necesitas
  1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: paso 1, imagen 1 de 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: paso 1, imagen 2 de 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: paso 1, imagen 3 de 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: paso 2, imagen 1 de 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: paso 3, imagen 1 de 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: paso 4, imagen 1 de 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: paso 5, imagen 1 de 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: paso 6, imagen 1 de 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: paso 7, imagen 1 de 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: paso 8, imagen 1 de 2 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: paso 8, imagen 2 de 2
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
  9. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: paso 9, imagen 1 de 2 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: paso 9, imagen 2 de 2
    • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
  10. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: paso 10, imagen 1 de 1
    • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
    • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
Conclusión
3 personas más completaron esta guía.
Westley Courchene
Miembro Desde 01/13/15
3,389 Reputación
14 Guías creadas
Equipo
USF Tampa, Team 1-1, Remmell Fall 2015 Miembro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 1,466
