Saltar al contenido principal
Creative Zen Vision W LCD Screen Replacement
Qué necesitas
  1. Creative Zen Vision W LCD Screen Replacement, Front Cover: paso 1, imagen 1 de 2 Creative Zen Vision W LCD Screen Replacement, Front Cover: paso 1, imagen 2 de 2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W LCD Screen Replacement: paso 2, imagen 1 de 3 Creative Zen Vision W LCD Screen Replacement: paso 2, imagen 2 de 3 Creative Zen Vision W LCD Screen Replacement: paso 2, imagen 3 de 3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W LCD Screen Replacement, LCD Screen: paso 3, imagen 1 de 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: paso 3, imagen 2 de 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: paso 3, imagen 3 de 3
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W LCD Screen Replacement: paso 4, imagen 1 de 1
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W LCD Screen Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W LCD Screen Replacement: paso 6, imagen 1 de 3 Creative Zen Vision W LCD Screen Replacement: paso 6, imagen 2 de 3 Creative Zen Vision W LCD Screen Replacement: paso 6, imagen 3 de 3
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
Conclusión
Una persona más ha completado esta guía.
Tim Wilson
Miembro Desde 04/11/13
143 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-2, Regan Spring 2013 Miembro de Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Miembros
8 Guías creadas
Un comentario
Where can I get the screen
Home Watch - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,392
