Saltar al contenido principal
Creative Zen V Plus Logic Board Replacement
Qué necesitas
  1. Creative Zen V Plus Logic Board Replacement, Prerequisite Only: paso 1, imagen 1 de 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Logic Board Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Logic Board Replacement: paso 3, imagen 1 de 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Logic Board Replacement: paso 4, imagen 1 de 2 Creative Zen V Plus Logic Board Replacement: paso 4, imagen 2 de 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Logic Board Replacement: paso 5, imagen 1 de 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Logic Board Replacement: paso 6, imagen 1 de 3 Creative Zen V Plus Logic Board Replacement: paso 6, imagen 2 de 3 Creative Zen V Plus Logic Board Replacement: paso 6, imagen 3 de 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Logic Board Replacement, Logic Board: paso 7, imagen 1 de 1
    • Unplug the logic board from the battery. Replace the logic board with your new logic board and reassemble your device.
Conclusión
Joel Ng
Miembro Desde 10/19/16
242 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-5, Baechle Fall 2016 Miembro de IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 489
