Saltar al contenido principal
Creative Nomad Jukebox Zen Display Screen Replacement
Qué necesitas
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: paso 1, imagen 1 de 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: paso 1, imagen 2 de 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: paso 1, imagen 3 de 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: paso 2, imagen 1 de 3 Creative Nomad Jukebox Zen Display Screen Replacement: paso 2, imagen 2 de 3 Creative Nomad Jukebox Zen Display Screen Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: paso 3, imagen 1 de 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: paso 4, imagen 1 de 1
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: paso 5, imagen 1 de 2 Creative Nomad Jukebox Zen Display Screen Replacement: paso 5, imagen 2 de 2
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: paso 6, imagen 1 de 2 Creative Nomad Jukebox Zen Display Screen Replacement: paso 6, imagen 2 de 2
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: paso 7, imagen 1 de 1
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
Conclusión
Austin Shaw
Miembro Desde 03/08/17
101 Reputación
1 Guía escrita
Equipo
IUPUI, Team S4-G5, Baechle Spring 2017 Miembro de IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 525
