Saltar al contenido principal
Creative Nomad Jukebox Zen Battery Replacement
Qué necesitas
  1. Creative Nomad Jukebox Zen Battery Replacement, Battery: paso 1, imagen 1 de 3 Creative Nomad Jukebox Zen Battery Replacement, Battery: paso 1, imagen 2 de 3 Creative Nomad Jukebox Zen Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Battery Replacement: paso 2, imagen 1 de 2 Creative Nomad Jukebox Zen Battery Replacement: paso 2, imagen 2 de 2
    • Use plastic opening tool to open top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Battery Replacement: paso 3, imagen 1 de 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover.
  4. Creative Nomad Jukebox Zen Battery Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to unclip the metal bracket holding the battery down.
    • When sticker is torn warranty is void.
  5. Creative Nomad Jukebox Zen Battery Replacement: paso 5, imagen 1 de 2 Creative Nomad Jukebox Zen Battery Replacement: paso 5, imagen 2 de 2
    • Desolder both red and black wires coming from battery.
    • Cómo soldar y desoldar conexiones Use soldering gun with care as it becomes extremely hot and can cause burns.
    • Make sure to solder the black and red wires back into the same locations.
Conclusión
Eli Richter
Miembro Desde 03/08/17
301 Reputación
3 Guías creadas
Equipo
IUPUI, Team S4-G5, Baechle Spring 2017 Miembro de IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 1,220
