Partes
No se requieren partes.
  1. Using your thumb, slide down and remove the battery cover.
    • Using your thumb, slide down and remove the battery cover.
  2. Using your index finger, remove the old AA battery.
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
  3. Slide down the eject button.
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
  4. Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
    • Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Lift the back cover off of the NOMAD II.
    • Lift the back cover off of the NOMAD II.
    • Remove the rubber USB port cover, the connected buttons along the left edge, and the plastic lock/unlock button on the upper right edge of the device.
  7. Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
  8. Carefully remove the battery compartment.
    • Carefully remove the battery compartment.
  9. Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
  10. Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
    • Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
  11. Pull the circuit boards out of the back cover.
    • Pull the circuit boards out of the back cover.
    • During reinstallation, firmly press the top of the circuit boards into the cover until you hear a click.
  12. Gently pry the circuit boards apart.
    • Gently pry the circuit boards apart.
    • This must be done with the USB port facing up, as shown.
  13. Desolder the seven solder joints which hold the lock switch in place.
    • Desolder the seven solder joints which hold the lock switch in place.
    • Install the new lock/unlock switch.
Conclusión
Craig Fischer
Miembro Desde 24/01/12
21 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-2, Regan Winter 2012 Miembro de Cal Poly, Team 9-2, Regan Winter 2012
CPSU-REGAN-W12S9G2
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,695
