Saltar al contenido principal
Creality Ender 3 Pro Hotend Nozzle Replacement
Qué necesitas
  1. Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: paso 1, imagen 1 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: paso 1, imagen 2 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: paso 1, imagen 3 de 3
    • Press the knob to enter the Ender 3 Pro menu.
    • Turn the knob to navigate to the temperature menu.
    • Click on the nozzle setting found in the temperature menu.
    • Turn the knob to set the nozzle to 200 C.
  2. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 2, imagen 1 de 1
    • Wait for the nozzle to heat up.
    • The nozzle will be at 200 C and should be handled with care to avoid burning yourself.
  3. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 3, imagen 1 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 3, imagen 2 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 3, imagen 3 de 3
    • Depress the extruder spring using the handle.
    • Pull the filament from the extruder, while keeping constant pressure on the extruder spring.
  4. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 4, imagen 1 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 4, imagen 2 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 4, imagen 3 de 3
    • Unscrew the two screws holding the fan shroud in place using the proper Allen key.
  5. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 5, imagen 1 de 2 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 5, imagen 2 de 2
    • The hot end is still at 200 C, so be careful not to burn yourself!
    • Remove the silicon sock covering the hot end and nozzle.
  6. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 6, imagen 1 de 2 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 6, imagen 2 de 2
    • Grab the hotend at the specified points using an adjustable wrench.
    • Be careful to avoid clamping the wires, ensuring the adjustable wrench only grabs the metal.
  7. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 7, imagen 1 de 2 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 7, imagen 2 de 2
    • Remove the nozzle with a 7mm socket wrench.
  8. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 8, imagen 1 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 8, imagen 2 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 8, imagen 3 de 3
    • Place the new nozzle within the 7mm socket wrench.
    • Grab the hotend using the adjustable wrench as seen in step 7.
    • Screw in the new nozzle again using the 7mm socket wrench.
    • Ensure the nozzle is hand tight as to not damage the hotend.
  9. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 9, imagen 1 de 2 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 9, imagen 2 de 2
    • Reattach the fan shroud by screwing in the two screws.
    • Place the silicon sock back on the hot end, avoiding contact with the metal.
  10. Creality Ender 3 Pro Hotend Nozzle Replacement: paso 10, imagen 1 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 10, imagen 2 de 3 Creality Ender 3 Pro Hotend Nozzle Replacement: paso 10, imagen 3 de 3
    • Navigate back to the temperature menu.
    • Set the nozzle temperature to 0 C, allowing it to cool down fully.
Linea de Meta
Vincent Lowe
Miembro Desde 02/21/23
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 36
Todo El Tiempo: 436
