Saltar al contenido principal
Creality Ender 3 Pro Extruder Replacement
Qué necesitas
  1. Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: paso 1, imagen 1 de 3 Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: paso 1, imagen 2 de 3 Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: paso 1, imagen 3 de 3
    • Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
    • Navigate to Temperature > Nozzle.
    • Adjust the nozzle temperature by turning the knob and confirm by pressing it.
    • Use whatever temperature you would be printing with, minus about 10°C. For both PLA and PETG 210°C usually works fine.
  2. Creality Ender 3 Pro Extruder Replacement, Wait for the hotend to heat up: paso 2, imagen 1 de 1
    • Wait until the current temperature (bottom) matches the target temperature (top).
  3. Creality Ender 3 Pro Extruder Replacement, Pull the filament: paso 3, imagen 1 de 1
    • Press down on the extruder lever arm and pull out the loaded filament.
    • Fully pressing down the lever arm might lead to the filament snagging when you try to pull it out. Just pressing it a bit will usually suffice.
  4. Creality Ender 3 Pro Extruder Replacement, Set cooldown: paso 4, imagen 1 de 1
    • Navigate to Temperature and press Cooldown.
    • If you do not have the Cooldown-option available, you can just repeat step one and set the temperature to 0°C instead.
  5. Creality Ender 3 Pro Extruder Replacement, Extruder: paso 5, imagen 1 de 3 Creality Ender 3 Pro Extruder Replacement, Extruder: paso 5, imagen 2 de 3 Creality Ender 3 Pro Extruder Replacement, Extruder: paso 5, imagen 3 de 3
    • Use a 8 mm wrench or some pliers to unscrew the PTFE tube from the extruder mechanism.
  6. Creality Ender 3 Pro Extruder Replacement: paso 6, imagen 1 de 2 Creality Ender 3 Pro Extruder Replacement: paso 6, imagen 2 de 2
    • Unscrew the single M3x18 socket head screw with a 2.5 mm hex key.
    • Remove the extruder arm and spring.
  7. Creality Ender 3 Pro Extruder Replacement: paso 7, imagen 1 de 2 Creality Ender 3 Pro Extruder Replacement: paso 7, imagen 2 de 2
    • Use a 2 mm hex key to remove the three remaining M3x10 socket head screws while making sure to not let the motor drop.
    • Remove the plastic bracket and the motor.
  8. Creality Ender 3 Pro Extruder Replacement: paso 8, imagen 1 de 3 Creality Ender 3 Pro Extruder Replacement: paso 8, imagen 2 de 3 Creality Ender 3 Pro Extruder Replacement: paso 8, imagen 3 de 3
    • Install the replacement extruder and screw it to the motor, following all the previous steps backwards.
  9. Creality Ender 3 Pro Extruder Replacement: paso 9, imagen 1 de 2 Creality Ender 3 Pro Extruder Replacement: paso 9, imagen 2 de 2
    • Reattach the PTFE tube to the extruder and insert some filaments.
Conclusión
Don't forget to recalibrate your E steps!
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 38
Ultimos 30 días: 118
Todo El Tiempo: 3,970
