Saltar al contenido principal
Craig Electronics CMP773 Volume/Power Control Button Replacement
Qué necesitas
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: paso 1, imagen 1 de 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: paso 2, imagen 1 de 1
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: paso 3, imagen 1 de 1
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: paso 4, imagen 1 de 1
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: paso 5, imagen 1 de 2 Craig Electronics CMP773 Volume/Power Control Button Replacement: paso 5, imagen 2 de 2
    • Remove the old button and replace it with the new one.
Conclusión
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
Miembro Desde 03/26/18
171 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G5, Harley Spring 2018 Miembro de IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 186
