Saltar al contenido principal
Craig CMP801 Battery Replacement
Qué necesitas
  1. Craig CMP801 Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Craig CMP801 Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: paso 2, imagen 1 de 2 Craig CMP801 Battery Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: paso 3, imagen 1 de 2 Craig CMP801 Battery Replacement: paso 3, imagen 2 de 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: paso 4, imagen 1 de 3 Craig CMP801 Battery Replacement, Battery: paso 4, imagen 2 de 3 Craig CMP801 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: paso 5, imagen 1 de 3 Craig CMP801 Battery Replacement: paso 5, imagen 2 de 3 Craig CMP801 Battery Replacement: paso 5, imagen 3 de 3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Where do I find a battery cmp749 ???
kourriclay929 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 1,007
