Saltar al contenido principal
Craftsman Model 315.10721 Table Guard Replacement
Qué necesitas
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: paso 1, imagen 1 de 1
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: paso 2, imagen 1 de 1
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: paso 3, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: paso 4, imagen 1 de 1
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Conclusión
Una persona más ha completado esta guía.
Riley Hilliker
Miembro Desde 10/14/14
557 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-47, Amido Fall 2014 Miembro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Miembros
5 Guías creadas
2 comentarios
Where can I get a replacement table guard???
Roger Coyle - Contestar
Where can I get a replacement table guard for this jig saw????????
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 612
