Saltar al contenido principal
Craftsman Model 315.10721 Cord Replacement
Qué necesitas
  1. Craftsman Model 315.10721 Cord Replacement, Cord: paso 1, imagen 1 de 1
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
    • Each screw has a corresponding nut on the opposite side of the power saw
  2. Craftsman Model 315.10721 Cord Replacement: paso 2, imagen 1 de 1
    • Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
  3. Craftsman Model 315.10721 Cord Replacement: paso 3, imagen 1 de 2 Craftsman Model 315.10721 Cord Replacement: paso 3, imagen 2 de 2
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the power cord are plugged in.
    • Release both the black and white wires and gently pull them from the leads.
    • To install the new cord, insert the wires of the new cord in the same way that they were removed.
Conclusión
Riley Hilliker
Miembro Desde 10/14/14
557 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-47, Amido Fall 2014 Miembro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 473
