Saltar al contenido principal
Craftsman Model 315.10721 Brush Replacement
Qué necesitas
  1. Craftsman Model 315.10721 Brush Replacement, Brush: paso 1, imagen 1 de 2 Craftsman Model 315.10721 Brush Replacement, Brush: paso 1, imagen 2 de 2
    • Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
  2. Craftsman Model 315.10721 Brush Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
    • The washer is seurely held in place and may require force to remove
  3. Craftsman Model 315.10721 Brush Replacement: paso 3, imagen 1 de 1
    • After the washers are removed, gently grab the old brushes and remove them from the motor.
    • When reassembling make sure the curvature of the brushes match curvature of the motor.
Conclusión
Riley Hilliker
Miembro Desde 10/14/14
557 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-47, Amido Fall 2014 Miembro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,405
