Saltar al contenido principal
Craftsman Model 315.10721 Blade Replacement
Qué necesitas
  1. Craftsman Model 315.10721 Blade Replacement, Blade: paso 1, imagen 1 de 1
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: paso 2, imagen 1 de 1
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
Linea de Meta
Riley Hilliker
Miembro Desde 10/14/14
557 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-47, Amido Fall 2014 Miembro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Miembros
5 Guías creadas
2 comentarios
Where can I get replacement blades for this saw.
Edward - Contestar
Where can I get replacement blades for this saw?
Edward - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 59
Todo El Tiempo: 3,328
