Saltar al contenido principal
Craftsman 944.360480 Carburetor O-Ring Replacement
Qué necesitas
  1. Craftsman 944.360480 Carburetor O-Ring Replacement, Carburetor O-Ring: paso 1, imagen 1 de 1
    • Make sure your engine is completely shut down and cooled off prior to starting this repair.
    • Put gloves on, so you don’t get any oil or gasoline on your skin.
  2. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 2, imagen 1 de 1
    • Use a flathead screwdriver and remove the 40 mm screw that secures the air filter and the case to the lawn mower.
  3. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 3, imagen 1 de 1
    • Carefully remove the air filter and set it aside.
  4. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 4, imagen 1 de 1
    • Slowly remove the air filter case from the hinges by tilting it slightly and pulling it out.
  5. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 5, imagen 1 de 1
    • Use the socket wrench and put the 5/16” inch hex bit on to remove the three 20 mm bolts located behind the air filter.
  6. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 6, imagen 1 de 1
    • Pull the plastic backing off which will expose the carburetor.
  7. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 7, imagen 1 de 2 Craftsman 944.360480 Carburetor O-Ring Replacement: paso 7, imagen 2 de 2
    • Use utility pliers to pull out the fuel line slowly by wiggling it up and down.
    • Have a container ready to pour out any extra fuel left in the mower.
    • Be sure to put a cloth or rag under if you don’t want it spilling anywhere.
  8. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 8, imagen 1 de 1
    • Use the socket wrench with a ½” inch hex bit to remove the 11 mm screw on the bottom of the tank.
  9. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 9, imagen 1 de 2 Craftsman 944.360480 Carburetor O-Ring Replacement: paso 9, imagen 2 de 2
    • Pull the carburetor tank down slowly.
    • Empty any extra gasoline and use a rag to clean it out.
  10. Craftsman 944.360480 Carburetor O-Ring Replacement: paso 10, imagen 1 de 1
    • Remove the O-Ring from the carburetor tank and replace it with a new one. You are ready to reassemble your lawnmower!
Conclusión
Priyum Mistry
Miembro Desde 01/10/22
181 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 559
