Saltar al contenido principal
Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank Replacement
Qué necesitas
  1. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: paso 1, imagen 1 de 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: paso 1, imagen 2 de 2
    • Remove the fuel line from the fuel tank with pliers.
  2. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 2, imagen 1 de 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 2, imagen 2 de 2
    • Take off the fuel cap and place a safe container under the fuel line.
    • Make sure to drain all of the fuel from the fuel tank into the container.
  3. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 3, imagen 1 de 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 3, imagen 2 de 2
    • Remove the four support bolts on the top of the tank and motor with a crescent wrench or socket wrench.
  4. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 4, imagen 1 de 1
    • Lift the fuel tank off of the lower supporting brackets.
  5. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 5, imagen 1 de 1
    • Replace the cracked fuel tank and place the new one onto the lower supporting brackets.
  6. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 6, imagen 1 de 1
    • Screw in the top four supporting bracket bolts with a crescent wrench or socket wrench to hold the new fuel tank in place.
  7. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 7, imagen 1 de 1
    • Reconnect the fuel line and hose clamp.
  8. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: paso 8, imagen 1 de 1
    • Fill the tank with fuel.
    • Check to make sure that the hose clamp is not leaking.
Conclusión
Megan Smith
Miembro Desde 10/07/19
169 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 2,241
