Saltar al contenido principal
Cr-48 Chromebook SSD Replacement
Qué necesitas
  1. Cr-48 Chromebook SSD Replacement, Battery: paso 1, imagen 1 de 3 Cr-48 Chromebook SSD Replacement, Battery: paso 1, imagen 2 de 3 Cr-48 Chromebook SSD Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: paso 2, imagen 1 de 2 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: paso 2, imagen 2 de 2
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: paso 3, imagen 1 de 3 Cr-48 Chromebook SSD Replacement, Remove Screws: paso 3, imagen 2 de 3 Cr-48 Chromebook SSD Replacement, Remove Screws: paso 3, imagen 3 de 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook SSD Replacement: paso 4, imagen 1 de 3 Cr-48 Chromebook SSD Replacement: paso 4, imagen 2 de 3 Cr-48 Chromebook SSD Replacement: paso 4, imagen 3 de 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: paso 5, imagen 1 de 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: paso 5, imagen 2 de 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: paso 5, imagen 3 de 3
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: paso 6, imagen 1 de 2 Cr-48 Chromebook SSD Replacement, Remove SSD: paso 6, imagen 2 de 2
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
Conclusión
5 personas más completaron esta guía.
Athar
Miembro Desde 09/09/14
365 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team 2-2, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 68
Todo El Tiempo: 3,062
