Saltar al contenido principal
Cover Panel Disassembly
Qué necesitas
  1. Cover Panel Disassembly, Cover Panel: paso 1, imagen 1 de 1
    • Find the mating groove running along the side of device. Use an ifixit opening tool to pry the two mating surfaces apart with a twisting motion.
    • Once the surfaces have been separated, using your fingers, pull the two surfaces apart evenly around the edge of the device.
    • During reassembly, be sure to press the two pieces together all the way around the perimeter to ensure good connection.
Conclusión
To reassemble your device, follow these steps in reverse order.
Brock Schaffer
Miembro Desde 10/26/16
463 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-5, Baechle Fall 2016 Miembro de IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 196
