Saltar al contenido principal
Corsair Katar Scroll Wheel Replacement
Qué necesitas
  1. Corsair Katar Scroll Wheel Replacement, Corsair Katar Disassembly: paso 1, imagen 1 de 2 Corsair Katar Scroll Wheel Replacement, Corsair Katar Disassembly: paso 1, imagen 2 de 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Scroll Wheel Replacement: paso 2, imagen 1 de 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Scroll Wheel Replacement: paso 3, imagen 1 de 2 Corsair Katar Scroll Wheel Replacement: paso 3, imagen 2 de 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Scroll Wheel Replacement: paso 4, imagen 1 de 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar Scroll Wheel Replacement, Scroll Wheel: paso 5, imagen 1 de 2 Corsair Katar Scroll Wheel Replacement, Scroll Wheel: paso 5, imagen 2 de 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar Scroll Wheel Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar Scroll Wheel Replacement: paso 7, imagen 1 de 1
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
Conclusión
Equipo
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 55
Todo El Tiempo: 1,956
