Saltar al contenido principal
Corsair HS80 Earpad Replacement
Qué necesitas
  1. Corsair HS80 Earpad Replacement, Earpad: paso 1, imagen 1 de 3 Corsair HS80 Earpad Replacement, Earpad: paso 1, imagen 2 de 3 Corsair HS80 Earpad Replacement, Earpad: paso 1, imagen 3 de 3
    • Remove the earpad from the headset by holding the earpad and twisting clockwise.
    • The earpad may be difficult to remove if doing so for the first time.
  2. Corsair HS80 Earpad Replacement: paso 2, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 2, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 2, imagen 3 de 3
    • Clean the area around the earpad speakers and cushion. A paper towel will suffice if only dust is being cleaned off.
  3. Corsair HS80 Earpad Replacement: paso 3, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 3, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 3, imagen 3 de 3
    • Take a pair of scissors and cut the old adhesive as close as possible to the fabric still adhered.
    • This will leave space on the cushion for new adhesive.
  4. Corsair HS80 Earpad Replacement: paso 4, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 4, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 4, imagen 3 de 3
    • Apply adhesive to the free edge of the earpad where the cushion had detached.
    • Wear gloves while working with adhesive. You may super glue your fingers together or your skin to the project. Have a glue debonder on hand if gloves are not available.
  5. Corsair HS80 Earpad Replacement: paso 5, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 5, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 5, imagen 3 de 3
    • Pull the fabric to the newly prepared earpad and hold it flush to the black lining of the earpad.
  6. Corsair HS80 Earpad Replacement: paso 6, imagen 1 de 2 Corsair HS80 Earpad Replacement: paso 6, imagen 2 de 2
    • Wrap masking or painter's tape to hold the fabric and earpad together.
  7. Corsair HS80 Earpad Replacement: paso 7, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 7, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 7, imagen 3 de 3
    • Insert a needle or sewing pin to hold the tape in place while the adhesive dries.
  8. Corsair HS80 Earpad Replacement: paso 8, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 8, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 8, imagen 3 de 3
    • Once dry, remove the pin and tape from the earpad.
  9. Corsair HS80 Earpad Replacement: paso 9, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 9, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 9, imagen 3 de 3
    • Reattach the earpad by lining the earpad in a clockwise direction and twist counter-clockwise to secure the earpad back into place.
Linea de Meta
miaLau
Miembro Desde 10/23/24
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 23
Todo El Tiempo: 62
