Saltar al contenido principal
Corsair Dark Core RGB PRO SE Right Side Hand Grip Replacement
  1. Corsair Dark Core RGB PRO SE Right Side Hand Grip Replacement, Right Side Hand Grip: paso 1, imagen 1 de 1
    • Find the crevice or gap between the mouse itself and the right hand grip.
  2. Corsair Dark Core RGB PRO SE Right Side Hand Grip Replacement: paso 2, imagen 1 de 2 Corsair Dark Core RGB PRO SE Right Side Hand Grip Replacement: paso 2, imagen 2 de 2
    • Place your pointer finger on the gap on the bottom of the mouse and your thumb on the top gap. Apply slight force and pull the grip off.
    • An alternative to pulling the grip off is to pinch at the bottom gap and side, pinching the grip off.
    • The standard, original, right hand grip is stuck to the mouse due to internal magnets. This is the mild resistance pulling against you.
  3. Corsair Dark Core RGB PRO SE Right Side Hand Grip Replacement: paso 3, imagen 1 de 2 Corsair Dark Core RGB PRO SE Right Side Hand Grip Replacement: paso 3, imagen 2 de 2
    • Hover the replacement grip closely over the area where the original side grip previously was and the new replacement grip should fit nicely into place due to the internal magnets.
Linea de Meta
Alexandria Jaimes
Miembro Desde 02/09/23
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 250
