Saltar al contenido principal
Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement
Qué necesitas
  1. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Glide Pads: paso 1, imagen 1 de 2 Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Glide Pads: paso 1, imagen 2 de 2
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Use the heat gun on the bottom of the mouse to loosen the glue on the pads.
    • Repeat this step with the other glide pads.
  2. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Mouse Nano-Switches: paso 2, imagen 1 de 1
    • Remove the two screws from the bottom of the mouse using a T5 Torx screwdriver.
  3. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: paso 3, imagen 1 de 1
    • Gently pry open the mouse shell using an iFixit opening tool.
    • Be careful not to force anything or use excessive force, as you may damage the components inside the mouse.
  4. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: paso 4, imagen 1 de 1
    • Use an iFixit opening tool to gently pry up the right and left click buttons on the top cover of the mouse until they pop out of place.
    • Be careful not to damage the wiring harnesses that connect the buttons to the PCB.
  5. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: paso 5, imagen 1 de 1
    • Use an iFixit opening tool to gently lift the top cover from the mouse body.
    • Be careful not to damage the wires connecting the cover to the mouse PCB.
  6. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: paso 6, imagen 1 de 1
    • Using a plastic opening tool, gently pry up the side button assemblies until they pop out of place.
  7. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: paso 7, imagen 1 de 1
    • Remove the screws that hold the circuit board in place using a Phillips #0 screwdriver.
    • Gently lift the PCB and set it aside.
  8. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • With the nano-switches now exposed, use a soldering iron to melt the solder holding the old switches in place.
    • Use tweezers to carefully remove the old switches and desolder any remaining solder.
Conclusión
Enzo Mello e Silva
Miembro Desde 02/09/23
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 47
Todo El Tiempo: 593
