Saltar al contenido principal
Corning PC-351 Hot Plate Heating Surface Replacement
Qué necesitas
  1. Corning PC-351 Hot Plate Heating Surface Replacement, Heating Surface: paso 1, imagen 1 de 2 Corning PC-351 Hot Plate Heating Surface Replacement, Heating Surface: paso 1, imagen 2 de 2
    • Unplug the hot plate and ensure it's fully cooled before beginning.
    • Flip the hot plate over so that the heating surface is facing downwards.
  2. Corning PC-351 Hot Plate Heating Surface Replacement: paso 2, imagen 1 de 1
    • Remove the four bottom panel 3 x 12 mm screws with a Phillips #2 screwdriver.
    • Detach the bottom panel.
  3. Corning PC-351 Hot Plate Heating Surface Replacement: paso 3, imagen 1 de 2 Corning PC-351 Hot Plate Heating Surface Replacement: paso 3, imagen 2 de 2
    • Remove the four heating surface 3 x 16 mm screws with a Phillips #2 screwdriver.
  4. Corning PC-351 Hot Plate Heating Surface Replacement: paso 4, imagen 1 de 2 Corning PC-351 Hot Plate Heating Surface Replacement: paso 4, imagen 2 de 2
    • Detach the heating surface lead wire connectors (the white wires) from the power supply with a pair of needle nose pliers.
  5. Corning PC-351 Hot Plate Heating Surface Replacement: paso 5, imagen 1 de 1
    • Separate the hot plate body from the damaged or dirty heating surface and place the new heating surface below the body.
  6. Corning PC-351 Hot Plate Heating Surface Replacement: paso 6, imagen 1 de 3 Corning PC-351 Hot Plate Heating Surface Replacement: paso 6, imagen 2 de 3 Corning PC-351 Hot Plate Heating Surface Replacement: paso 6, imagen 3 de 3
    • Connect the new hot plate heating surface lead wire connectors (the white wires).
    • Carefully thread the left lead wire connector below the heating coil.
    • You will need to feed the left lead wire below the heating coil for it to reach the connection
  7. Corning PC-351 Hot Plate Heating Surface Replacement: paso 7, imagen 1 de 1
    • Fasten the four hot plate heating surface 3 x 16 mm screws using a Phillips #2 screwdriver.
  8. Corning PC-351 Hot Plate Heating Surface Replacement: paso 8, imagen 1 de 1
    • Attach the bottom panel and fasten the bottom panel 3 x 12 MM screws using a Phillips #2 screwdriver.
  9. Corning PC-351 Hot Plate Heating Surface Replacement: paso 9, imagen 1 de 2 Corning PC-351 Hot Plate Heating Surface Replacement: paso 9, imagen 2 de 2
    • Flip the hot plate right side up, so that the heating surface is now facing upwards.
Conclusión
To reassemble your device, follow instructions after step 6. Thank you for reading our guide, and we hope you found it helpful!
DericHoward
Miembro Desde 09/25/24
169 Reputación
1 Guía escrita
Equipo
CSU Sacramento, Team 1-16, Laflen Fall 2024 Miembro de CSU Sacramento, Team 1-16, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G16
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 79
