Saltar al contenido principal
Copic Marker Nib Replacement
Qué necesitas
  1. Copic Marker Nib Replacement, Copic Marker Nib: paso 1, imagen 1 de 1
    • Place a few paper towels on the surface of your workspace to protect it from ink spills.
  2. Copic Marker Nib Replacement: paso 2, imagen 1 de 1
    • Remove the cap from the marker to expose the nib.
  3. Copic Marker Nib Replacement: paso 3, imagen 1 de 3 Copic Marker Nib Replacement: paso 3, imagen 2 de 3 Copic Marker Nib Replacement: paso 3, imagen 3 de 3
    • Gently tug out the thicker part of the nib with the tweezer.
  4. Copic Marker Nib Replacement: paso 4, imagen 1 de 2 Copic Marker Nib Replacement: paso 4, imagen 2 de 2
    • Remove the cap of the ink bottle and tilt the container to begin filling the marker.
    • Avoid forcibly squeezing the ink bottle.
    • Slowly fill the pen until it is approximately 3/4ths of the way full.
  5. Copic Marker Nib Replacement: paso 5, imagen 1 de 3 Copic Marker Nib Replacement: paso 5, imagen 2 de 3 Copic Marker Nib Replacement: paso 5, imagen 3 de 3
    • Insert the flat side of the new nib facing the opening of the marker until it snaps into place.
    • Set the marker down after replacing new nib.
  6. Copic Marker Nib Replacement: paso 6, imagen 1 de 3 Copic Marker Nib Replacement: paso 6, imagen 2 de 3 Copic Marker Nib Replacement: paso 6, imagen 3 de 3
    • Wait 3 minutes for the color to spread through the nib until it is no longer white.
    • Press on the middle of the marker 3 times to insure ink is spread throughout.
    • Repeat steps 3 - 5 if the amount of ink is insufficient.
Linea de Meta
2 personas más completaron esta guía.
Iris Lin
Miembro Desde 04/28/17
149 Reputación
1 Guía escrita
Equipo
UC Davis, Team S1-G5, Coad Spring 2017 Miembro de UC Davis, Team S1-G5, Coad Spring 2017
UCD-COAD-S17S1G5
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 29
Todo El Tiempo: 2,800
