Saltar al contenido principal
Coolpix S01 USB Cover Replacement
Qué necesitas
  1. Coolpix S01 USB Cover Replacement, USB Cover: paso 1, imagen 1 de 3 Coolpix S01 USB Cover Replacement, USB Cover: paso 1, imagen 2 de 3 Coolpix S01 USB Cover Replacement, USB Cover: paso 1, imagen 3 de 3
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
    • Next remove the 2 mm screw from the right side of the camera.
  2. Coolpix S01 USB Cover Replacement: paso 2, imagen 1 de 3 Coolpix S01 USB Cover Replacement: paso 2, imagen 2 de 3 Coolpix S01 USB Cover Replacement: paso 2, imagen 3 de 3
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 USB Cover Replacement: paso 3, imagen 1 de 3 Coolpix S01 USB Cover Replacement: paso 3, imagen 2 de 3 Coolpix S01 USB Cover Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • On the bottom of the camera, locate the USB port.
    • Gently slide the USB cover off of the camera with your fingers or tweezers.
    • You can replace the USB cover by purchasing one from a local electronics store or online at iFixit.com.
Conclusión
Fernando Ochoa
Miembro Desde 10/13/15
113 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 394
