Saltar al contenido principal
Coolpix S01 Screen Cover Replacement
Qué necesitas
  1. Coolpix S01 Screen Cover Replacement, Screen Cover: paso 1, imagen 1 de 3 Coolpix S01 Screen Cover Replacement, Screen Cover: paso 1, imagen 2 de 3 Coolpix S01 Screen Cover Replacement, Screen Cover: paso 1, imagen 3 de 3
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
  2. Coolpix S01 Screen Cover Replacement: paso 2, imagen 1 de 3 Coolpix S01 Screen Cover Replacement: paso 2, imagen 2 de 3 Coolpix S01 Screen Cover Replacement: paso 2, imagen 3 de 3
    • Next, remove the 2 mm screw from the right side of the camera
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Screen Cover Replacement: paso 3, imagen 1 de 3 Coolpix S01 Screen Cover Replacement: paso 3, imagen 2 de 3 Coolpix S01 Screen Cover Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • With the screen facing outward, locate the orange ribbon cable from the motherboard.
    • With the straight tweezers, gently pull out the orange ribbon cable from the motherboard.
  4. Coolpix S01 Screen Cover Replacement: paso 4, imagen 1 de 3 Coolpix S01 Screen Cover Replacement: paso 4, imagen 2 de 3 Coolpix S01 Screen Cover Replacement: paso 4, imagen 3 de 3
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
    • Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 452
