Saltar al contenido principal
Coolpad Defiant Rear Camera Replacement
Qué necesitas
  1. Coolpad Defiant Rear Camera Replacement, Back Cover: paso 1, imagen 1 de 2 Coolpad Defiant Rear Camera Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Rear Camera Replacement: paso 2, imagen 1 de 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Rear Camera Replacement, Battery: paso 3, imagen 1 de 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Rear Camera Replacement, Rear Camera: paso 4, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
  5. Coolpad Defiant Rear Camera Replacement: paso 5, imagen 1 de 2 Coolpad Defiant Rear Camera Replacement: paso 5, imagen 2 de 2
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
  6. Coolpad Defiant Rear Camera Replacement: paso 6, imagen 1 de 1
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
  7. Coolpad Defiant Rear Camera Replacement: paso 7, imagen 1 de 3 Coolpad Defiant Rear Camera Replacement: paso 7, imagen 2 de 3 Coolpad Defiant Rear Camera Replacement: paso 7, imagen 3 de 3
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
  8. Coolpad Defiant Rear Camera Replacement: paso 8, imagen 1 de 3 Coolpad Defiant Rear Camera Replacement: paso 8, imagen 2 de 3 Coolpad Defiant Rear Camera Replacement: paso 8, imagen 3 de 3
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
  9. Coolpad Defiant Rear Camera Replacement: paso 9, imagen 1 de 1
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 286
