Introducción
Is your phone not taking photos properly? Consider using this guide to replace the rear camera in your device.
Qué necesitas
Turn the phone with the back cover facing towards you.
Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
Find the gap on the bottom of the battery.
With a tool or with your hands, pull the battery upward and set it aside safely.
Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
