Saltar al contenido principal
Coolpad Defiant Daughterboard Replacement
Qué necesitas
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: paso 1, imagen 1 de 2 Coolpad Defiant Daughterboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: paso 2, imagen 1 de 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: paso 3, imagen 1 de 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: paso 4, imagen 1 de 2 Coolpad Defiant Daughterboard Replacement, Daughterboard: paso 4, imagen 2 de 2
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: paso 5, imagen 1 de 3 Coolpad Defiant Daughterboard Replacement: paso 5, imagen 2 de 3 Coolpad Defiant Daughterboard Replacement: paso 5, imagen 3 de 3
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: paso 6, imagen 1 de 1
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
Conclusión
Elijah Gastin
Miembro Desde 09/21/18
100 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 450
