Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Is your device not properly turning on or charging? Consider using this guide to replace the battery in your phone.
Partes
No se especificaron partes.
  1. Turn the phone with the back cover facing towards you. Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Remove the back cover from your device.
    • Remove the back cover from your device.
  3. Find the gap on the bottom of the battery.
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 717
