Saltar al contenido principal
Coolpad Defiant Back Case Replacement
Qué necesitas
  1. Coolpad Defiant Back Case Replacement, Back Cover: paso 1, imagen 1 de 2 Coolpad Defiant Back Case Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Back Case Replacement: paso 2, imagen 1 de 1
    • Remove the back cover from your device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 312
