Saltar al contenido principal
Coolpad 3300A Camera Replacement
Qué necesitas
  1. Coolpad 3300A Camera Replacement, Coolpad 3300A Disassembly: paso 1, imagen 1 de 1
    • After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
  2. Coolpad 3300A Camera Replacement: paso 2, imagen 1 de 3 Coolpad 3300A Camera Replacement: paso 2, imagen 2 de 3 Coolpad 3300A Camera Replacement: paso 2, imagen 3 de 3
    • Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
  3. Coolpad 3300A Camera Replacement: paso 3, imagen 1 de 3 Coolpad 3300A Camera Replacement: paso 3, imagen 2 de 3 Coolpad 3300A Camera Replacement: paso 3, imagen 3 de 3
    • Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
  4. Coolpad 3300A Camera Replacement: paso 4, imagen 1 de 1
    • After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
  5. Coolpad 3300A Camera Replacement, Camera: paso 5, imagen 1 de 2 Coolpad 3300A Camera Replacement, Camera: paso 5, imagen 2 de 2
    • Carefully use the nylon spudger to pry the camera from its connector.
Conclusión
3 personas más completaron esta guía.
Cordell Miller
Miembro Desde 03/26/18
318 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G3, Harley Spring 2018 Miembro de IUPUI, Team S1-G3, Harley Spring 2018
IUPUI-HARLEY-S18S1G3
6 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 595
