Saltar al contenido principal
Convert PDF to JPEG, BMP, PNG and TIFF file formats
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Convert PDF to JPEG, BMP, PNG and TIFF file formats, Convert PDF to JPEG, BMP, PNG and TIFF file formats: paso 1, imagen 1 de 1
  2. Convert PDF to JPEG, BMP, PNG and TIFF file formats: paso 2, imagen 1 de 1
    • Click the option 'Select File' to load a desired PDF file for conversion. Alternatively, if you have forgotten the exact path of the PDF file saved on Mac, then the tool provides an option 'Find Files', which in turn will look for the PDF files in particular volume.
  3. Convert PDF to JPEG, BMP, PNG and TIFF file formats: paso 3, imagen 1 de 1
    • Once all the PDF files are uploaded on the software menu, choose the desired output images format. The PDF selected can be converted into JPEG, BMP, PNG and TIFF formats. These are wholly accepted images file formats and can be used in any project, presentation etc. All set! Proceed by clicking the 'CONVERT' button.
  4. Convert PDF to JPEG, BMP, PNG and TIFF file formats: paso 4, imagen 1 de 1
    • The conversion process may takes some time, typically in minutes depending on the PDF size, no. of pages to be converted etc. After the process finishes, PDF pages converted into image files are arranged on the left pane of the software interface. Use check box to select, de-select images to save on the hard drive.
Conclusión
4 personas más completaron esta guía.
Vishal Chaudhary
Miembro Desde 04/18/12
3,203 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 553
