Introducción
This guide will give you step-by-step instructions on how to replace the record slider on your Contour Roam2 waterproof action camera if the camera won't begin or end recording properly.
Qué necesitas
Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
3 personas más completaron esta guía.
2 comentarios
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
