Saltar al contenido principal
Contour Roam2 Lens Unit Replacement
Qué necesitas
  1. Contour Roam2 Lens Unit Replacement, Record Slider: paso 1, imagen 1 de 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Lens Unit Replacement: paso 2, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 2, imagen 2 de 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Lens Unit Replacement: paso 3, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 3, imagen 2 de 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Lens Unit Replacement: paso 4, imagen 1 de 3 Contour Roam2 Lens Unit Replacement: paso 4, imagen 2 de 3 Contour Roam2 Lens Unit Replacement: paso 4, imagen 3 de 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Lens Unit Replacement: paso 5, imagen 1 de 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
  6. Contour Roam2 Lens Unit Replacement, Mounting Piece: paso 6, imagen 1 de 2 Contour Roam2 Lens Unit Replacement, Mounting Piece: paso 6, imagen 2 de 2
    • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
  7. Contour Roam2 Lens Unit Replacement: paso 7, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 7, imagen 2 de 2
    • Open the back door by your thumb and index finger on sides of back door and pull upward.
  8. Contour Roam2 Lens Unit Replacement: paso 8, imagen 1 de 1
    • Using your thumb, pry sides outward on back of mount piece.
    • This will loosen mount piece for removal in proceeding step.
    • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
  9. Contour Roam2 Lens Unit Replacement: paso 9, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 9, imagen 2 de 2
    • Remove and replace mount piece.
  10. Contour Roam2 Lens Unit Replacement, Lens Unit: paso 10, imagen 1 de 2 Contour Roam2 Lens Unit Replacement, Lens Unit: paso 10, imagen 2 de 2
  11. Contour Roam2 Lens Unit Replacement: paso 11, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 11, imagen 2 de 2
    • With the phillips head screwdriver (PH000) remove the two 3.31mm (.130inch) screws located at the top, above the reset button.
  12. Contour Roam2 Lens Unit Replacement: paso 12, imagen 1 de 1
    • Also with phillips head screwdriver (PH000) remove the six 6.07mm (0.239in) screws along sides of large white piece.
  13. Contour Roam2 Lens Unit Replacement: paso 13, imagen 1 de 1
    • Locate notch on side of large white plastic piece.
  14. Contour Roam2 Lens Unit Replacement: paso 14, imagen 1 de 3 Contour Roam2 Lens Unit Replacement: paso 14, imagen 2 de 3 Contour Roam2 Lens Unit Replacement: paso 14, imagen 3 de 3
    • Remove white piece by pressing a fingernail in notch (located in previous step) and lifting up on white piece.
  15. Contour Roam2 Lens Unit Replacement: paso 15, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 15, imagen 2 de 2
    • The white piece is connected to logic board of camera by a ribbon connector.
    • To remove the white piece completely give a gentle pull on ribbon connector.
  16. Contour Roam2 Lens Unit Replacement: paso 16, imagen 1 de 1
    • With a phillips head screwdriver (PH 000), remove the 5.54 mm (0.218 in) screw located next to the tripod screw-in.
  17. Contour Roam2 Lens Unit Replacement: paso 17, imagen 1 de 3 Contour Roam2 Lens Unit Replacement: paso 17, imagen 2 de 3 Contour Roam2 Lens Unit Replacement: paso 17, imagen 3 de 3
    • Using the phillips head screwdriver (PH 000), remove the remaining three 3.78 mm (0.1445 in) screws located on the back panel of the camera.
    • If you have not done so already, remove the microSD card.
  18. Contour Roam2 Lens Unit Replacement: paso 18, imagen 1 de 1
    • Using the phillips head size PH000 screwdriver remove 3.67mm (0.1445 inch) screw located on the side of logic board within the body of the camera.
  19. Contour Roam2 Lens Unit Replacement: paso 19, imagen 1 de 3 Contour Roam2 Lens Unit Replacement: paso 19, imagen 2 de 3 Contour Roam2 Lens Unit Replacement: paso 19, imagen 3 de 3
    • Using flathead tweezers, remove the logic board and the battery from the camera.
  20. Contour Roam2 Lens Unit Replacement: paso 20, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 20, imagen 2 de 2
    • Using a phillips head screwdriver (PH 000), remove the screw connecting the lens unit to the logic board.
  21. Contour Roam2 Lens Unit Replacement: paso 21, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 21, imagen 2 de 2
    • Remove the semicircular white plastic strip near the lens unit.
  22. Contour Roam2 Lens Unit Replacement: paso 22, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 22, imagen 2 de 2
    • Twist lens unit until able to easily remove
  23. Contour Roam2 Lens Unit Replacement: paso 23, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 23, imagen 2 de 2
    • Disconnect the ribbon connector connecting the lens unit to the logic board.
  24. Contour Roam2 Lens Unit Replacement: paso 24, imagen 1 de 2 Contour Roam2 Lens Unit Replacement: paso 24, imagen 2 de 2
    • Remove the ribbon connecter from the lens unit by soldering.
Conclusión
2 personas más completaron esta guía.
Jamie Maple
Miembro Desde 03/11/15
310 Reputación
2 Guías creadas
Equipo
3 comentarios
hola amigos soy de venezuela, hace aproximadamente compre una -contour roam- y se me daño el flex del lente, pero aqui en venezuela no se encuentra ese repuesto y he buscado por internet y no encuentro, ustedes me podrian ayudar de alguna manera con ese problema? mi correo es luiswichin@gmail.com por favor se les agradece alguna respuesta.
luis gerardo - Contestar
hello friends I'm from Venezuela, does about buying a -contour roam- and hurt me flex the lens, but here in Venezuela is not the parts and I have searched the internet and can not find, you could help me somehow with that problem? my email is luiswichin@gmail.com are thanked please any response.
Hello! Where can we find the ribbon connector with 10 pins? Is to short to contain all code on the connector is vissible only JI-HAW AWM E1180… more is missing. I searched many days… I removed it gentle, but when I push it back the head of the band just separated from plastic and broke…
Ilie lucian - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 2,005
